noob question
I got an 06 TTR 250 and plan to do most maintenance myself. So I dont pull off the wrong cover and have 10 different gears and springs fall out, where is the oil filter located? Thanks
Its on the right side of the motor, right in front of the cover that says "YAMAHA" on it. Its the little cover about an inch and a half in diameter. Its bolted to the side case by three different length allen head bolts. The owners manual actually does a good job of outlining the oil changing procedure if you don't have the service manual
