i have rear anti lock brake on my crf
by accident. what is causing it. 85 hours on bike, original fluid , no leaks , brake pads only got 20 hours and look good. i stop on rear brake and it locks up then lets go . they feel soft. i tried adjusting nut but didnt seem to help. is the fluid shot, if so how hard is it to change?
at 85 hrs you are more than likely ready for a brake hose.
I doubt you need a new hose.
Change the fluid, at the very least try bleeding it out. That will probably do it.
My line was shot in about 55 hours, took rebuilding everything and a line to fix it. :ride:
But I woud start with fresh fluid and go from there. :thumbsup:
same thing happed to me and it was the brake line. if the fresh fluid and bleeding doesnt fix it. put a brake line on it before you rebuild the master cylinder or caliper
