Oil check bolt loosen's frequently
Is anyone else having this problem? I always have to tighten it before and during riding. I tighten it down pretty good, I dont wanna go any further and risk stripping it. :thumbsup:
John
If your talking about the clutch side then it should have a copper washer on there to hold it in place.A spot of thread lock will seal the threads.
You should be running 0.85 L in the tranny any ways as has been discussed on here for a while so the check level is bolt is irrelevant.
Lol. Its way to small.. and where the heck do you plan on safty wiring it to? Yeah there should be a copper washer on the bolt that could be your problem, if not just loc-tite that puppy in there.
safety wire? :thumbsup: ...... duct tape baby :ride: just put a lockwasher on there and that should help
it may not seal with a lock washer and you could have a slow leak, get a new brass washer.
They are copper crush washers and are not intended to be used over and over.........
