Which air filter and air filter oil is everyone using??
There's likely more than you care to read if you do a search on these topics. :thumbsup:
I use Hiflo filters and Castrol GTX 10W-40. What ever you use just be prudent on how long you go between changes and make sure to always install a new filter (or cleaned one if using a SS filter) each time you change oil. Also, you don't want to use an "energy conserving" oil if you go with an automotive oil as these have PTFE in them and are no good for a wet clutch (can cause slippage). The energy conserving designation is found on the little round oil service grade marking. :ride:
For the air side I use a Twin Air with NoToil oil.
factory and uni air with pj1
for oil i use synthetic blend good stuff-dont care what name is on it, i read the back of the jug, not the front
Moose filter with No Toil oil.
I can't believe how easy No Toil is to clean. :thumbsup::ride::applause::applause: I like the oversize Moose filter with the neoprene gasket on back.
I'm never going back to the old messy stuff.
BTW: I just found out the Kawasaki air filter oil kit is No Toil.
