05 damper rod disassembly
I just bought a 05 wr250f which had been lowered by 2 in. I was able to raise the rear up with no problem, with help from this great website and the manual. The front forks are more of a challenge.The springs that were in the forks had 2 in. cut off.I ordered and tried to install new Race-Tech springs but found preload at about 60 mm.when it should be at about 15 mm.I called Race-Tech and they said there has probably been a spacer installed in the damper rod cartridge.I have made the tools and removed the cartridge, again with help from this website,but can find no information on how to disassemble the cartridge correctly.Any info and/or pics would be greatly appreciated. :thumbsup::ride:
You may have better luck moving this to the suspension forum.
