YZ 85 plastics - ttr?
The YZ85 rear fender should fit..I know the YZ80 rear fender fits, its the same fender as the ttr, but just not positive if the YZ85 one will work on the TTR. The rest of the plastic wont...the front fender should work as well, cant tell ya for sure though..
Like said, the yz80 rear fender will for sure fit. The yz85 might also. The front fender should fit. I think I heard you had to use a few spacers though, not sure.
doenst the yz85/yz80 gripper seat fit to?
Does it? Anyone ever done it?
Been searching with no results
The seats do not fit. The front fender might work but it may hit the pipe. At least mine did with a YZ front end on. I just cut it down.
If it's 08 or 09 the YZ 80 rear fender doesn't fit. Well, it does(meaning the holes still line up), but the side panels over hange it so it doesn't line up like it used to.
YZ 80 front and rear fits. Front needs a mod (drill the location of the mounts for the wider TTR locations). Seats do not interchange. YZ 85 front fender will work with similar drill job, but rear fender does not.
-Kerry
