Clutch engagement adjustment possible?
2006 250f so far 3 hours on the bike, i use my middle finger to pull the clutch so the lever hits my other finger but thats not far enough for the clutch to completely disengage while in idle and it just stalls once i put it in first gear. I know the lever play can be adjusted and its adjusted to no play at all almost and i couldnt find anything on being able to adjust where you want the clutch to have its sweet spot.
Sounds like you need to look into the aftermarket adjustable pivot cluth perches available. This will allow you to have a lighter clutch up to approx 40% lighter & adjust the lever to be at the optimum position for your style.
Good Luck.
