shifting problems
What you will need to do is pull off the clutch cover and look at the star, pivoting roller arm, and shift shaft. Chances are one is bent or cracked. I had a transmission problem and the pivoting arm was cracked. It was rubbing on the primary driven gear and threw metal shavings all over the place.
Look at the oil filter screen in the top of this picture.
