RMZ 250 front and rear calipers.
Any one know if the front or rear calipers, from '02 and newer bikes, are a direct swap with the DRZ? I know the front rotor is, so I don't see why the caliper wouldn't be. And I'm not at all sure about the rear caliper.
yes,they are direct swap and no different than drz calipers.
you can also use the rear rm caliper carrier and then you can use the bigger rm rear rotor.
Thanks Ed. I go to flea markets and see good deals on stuff that I'm not sure will fir the DRZ. I ran accross an aftermarket RM rear caliper for the RM but I wasn't sure it would fit. Now I know, and knowing is half the battle.
