heavy duty kick start gears?
I put a 230 kit in my 150 and I read something awhile back about stress on the kick start gears... Someone mentioned push starting only.
Is there any type of upgrade that can be done to the kicker assembly to allow it to handle the extra compression and stress of the big bore kit...
'coeshow' is your guy for this...
According to an inquiry that I had sent him a while back about the HD starter gear:
"...The gears I offer will not quite "bolt in". There is a very minor case modification that needs to be performed for clearance. One of the three replacement gears is a bit larger and the case needs to be altered for proper tolerances. The gears sets do run $200.00. If you are able to perform the labor yourself, once the gears have been swapped, you will be able to clearly see the material that needs to be removed from the case during trial fitment."
