Ticky, ticky...valve clearance?
Does anyone know what the clearance spec. is for the intake/exhaust valves on an '02 DRZ 400E, I recently heard ticking and thought it might be an idea to check it at the same time I install my spanky-new-mcct.
Thanks,
Steve
.004-.008" intake .008-.012" ex.
never a bad time to check the valves,but highly unlikely they are loose unless some one set them that way.
Have the clearance specs changed over the years? My manual says:
.010 - .020 intake
.020 - .030 exhaust
for 2000 - 2004 for E models.
You might want to double check your manual, I have a feeling you are looking at the metric specs of 0.1 to 0.2mm Intake and 0.2 to 0.3mm Exhaust. These would be the equivalent to the inch specs Eddie supplied.
Yep, talking apples and oranges here :thumbsup:
Apples are deffinately metric, I think all citrus fruits are imperial. :thumbsup:
My bad. I definitely got my decimal in the wrong place :ride: . Metric clearance is 0.10 - 0.20 intake, 0.20 - 0.30 exhaust. :thumbsup:
Just as an FYI...
Checked mine tonight, at 4000 miles. All were within spec...
Intake Left... .006
Intake Right... .0055
Exhaust Left... .009
Exhaust Right... .0085
:thumbsup:
how often do are you supposed to check the valves on an 06 SM?
-patch :thumbsup:
Apples are deffinately metric, I think all citrus fruits are imperial. :applause:
:ride::thumbsup:
-patch :thumbsup:
The same as on any other SM/S/SR/E/K/R :ride:
Are you supposed to or should you?
According to suzuki you should check them after the first 5 hours and then every 60 hours for the off road models and for the dual sport versions aren't recommended until 15,000 miles. That is totally insane if you ask me.
Now I personally check mine at least monthly when I'm riding. More often if I'm doing a lot of fast, hard rides.
