Help: Front signals stopped working.
Both my front signals stopped working, nothing note worthy happened to cause it. The rear set still work but blink faster now. Any idea what would cause both to go out?
Thanks,
3rdGear
look under headlight shroud for the ground wires running from the two long thin connectors. I think they come together and run back to ground. If they both stopped working at the same time a bad connection to ground is the most likely cause.
