94 DR650, no tail light or plate light
as the title says, no rear lights. my fuse box ony has fuses for the headlights no tails. does anybody know where a fuse for the tail lights might be located? im lost. and the blinkers do work just no tails or plate light....ugh
I just studied the wiring diagram and there doesn't seem to be any fuses for the tail light. There are fuses for the high beam and low beam and that is it. Put a new bulb in. Sometimes you can't see the break in the filament although usually it is just one filament not both that goes. Failing that, start looking at the wires and do continuity checks.
problem solved. the tail light bulb socket has a ground wire crimped to the base. it looked fine on the out side no corrosion or anything, but it was all crappy on the inside i cut it and re-crimped it and now it lights up great. :thumbsup:
