Short Clutch/Brake Levers
Anyone know where to buy shorter than OEM clutch and brake levers that will fit a DR650? I'd rather not cut the balls off the stock levers.
Thanks.
I have same prob with clutch side only. Was told no one makes
a short lever unless you go with new perch, then you have
to find a way to mount mirror which Emgo makes a 10mm mirror
mount.
I would try different barkbusters if I new would solve prob.
I have MSR bark busters (guards) installed. The levers just barely fit with the wind deflectors installed but worked OK. The reason I need to shorten the levers is that the guards got smaked up during the Quarry Run last weekend and now they aren't fitting well.
Wayne
Ok dudes...easiest thing to do...just loosen the levers and slide them in. One thing that sucks ass though, is that there are little plastic nubs on the controls that fit into a little hole drilled in the stock handlebars(smart one Suzuki :thumbsup: ). I took my controls off and filed down the 2 nubs(one on start button/kill switch and one on horn/turn signal) when I installed new handlebars. This gives you the freedom to space out your controls the way you want and you can make room for roll chart holders and other crap you want to put on the bars. Hope this helps you guys.
