Which leak down tester??
I think have may have bent valves and would like to verify with a leak down tester. Anyone have a experience with a decent one? Anyone make one? I am assuming that it is a 14mm spark plug hole so it doesn't seem like it would be that hard to put one together.....
if you can,t get hold of a leak down tester just use the hose from a quick connect compression tester :thumbsup:
Anyone make one?
I made one, it wasn't too hard. I'll have to get some pics together if you'd like. I think it was $40ish including the spark plug adapter from a compression tester.
well the 14 and 18 mm stuff is for the auto and aviation stuff,
and the 10 and 12 is what you want for the bike world,
i have an old snap on unit that i have had for 35 years or more that i paid $125.0 for and it came with all 4 sizes ,
but i believe HARBOR fREIGHT has one on sail now for 39 bucks ( you might have to supply the 10 and 12mm adapter i am not sure,
and they have a Diesel one also for 39 bucks ----which is a deal ,
i had to pay $350.0 for my snap diesel one ! :ride::applause::applause:
but like was said earlier you can just use the hose from a compression tester and pump the cylinder full with shop air and listen where the big leak is
the only way a leak down does you any good is when you do a fresh motor you just built so you have a baseline on where it is cold and hot ,
i can get my crf motors right around 3 to 4 % leakage and you check them ever weekend and when they are 8 to 10 % you do them all over again.
which is generally every week or two ,
every week on the 250 ---that little motor goes away fast :applause:
if you check a worn out one you will easily see 35 % or more of leakage, :thumbsup:
I am not necessarily concerned with % leakage, I just need to find out if I have leakage past the valves. I suppose I only would need the adapter and an air hose to connect to shop air. Gauges wouldn't really be necessary. Is the CRF a 12mm???
yes just a hose to connect to shop air will suffice and alittle soapy water in a spray bottle ---
well i can not believe it but you were correct ,---i went out and picked up the wore out hose and fitting i use on the 250 and it is so wore out i can barley read the size on it but my 10 x 1.0 spark plug tap goes in the 250 hole ,
and now the hose and end i use on the 450 is almost wore out as bad but i can just reed 14 x 1.25 on the thing ------i still can't believe it but oh well i am very confused most of the time,
i have a 450 comming in here in an hr or so and i will have it apart very quickly and i will check it and make sure for you ----its looking like it is a 14 x 1.25 but i would have bet against it ---oh well i will write bike shortly :thumbsup: ----i am having one of those days :ride::applause:
