DJ Kit Spring
Did the 3x3/DJ Kit on my S the other day. When I was cleaning up I noticed that there was a replacement spring (the big one for the needle housing thingumbob) in the kit. Is this spring different than the stock one? Wondering if I should put it in...?
Thanks
This kit calls it a replacement (optional) I used it but it looks like its the same to me.
The optional spring is the small one. :thumbsup:
Compress the DJ spring and you will see it's much weaker, creating quicker throttle response.
I guess you could cheap out and cut a few mm's of the stock spring to give you the same effect.
ron W.
Thanks, all. I just put the DJ spring in and the difference is certainly noticeable.
