Xr 100 gives up/
my bike will not rev half way untill it starts crackling and finally stalls i need help !
thanks
Might be a clogged main jet on the carb. Take the carb off the bike and remove the float bowl (the lower half of the carb). You will find the main jet in there.
Try and figure out if it is lower RPM's or less throttle position that causes the problem.
What year 100??? blow air threw the pilot jet. What overall condition is the bike????
it is an 03' ... i know this might sound like a noob question but just to be sure, what positiong should the choke be when it is on?
Choke completely down is off. Check that, if that is fine, then blow out the pilot. Make sure you can see through it, before you put it back together.
