Yea, I think i messed up!
I've been wanting to make my 33 bhp restrictor off for a while and today i got around to doing it.
For those of you that dont know, it means i have to replace the carb diaphram!
So i took the seat & tank off and got my screwdrivers at the ready.
I managed to burr the screw head in a matter of seconds! Now i dont know :thumbsup: &%$#@! to do!
HELP! :ride:
Use a small pair of good channel lock type pliers to get ahold of the heads and turn them. They will crack loose. That is what I did with mine. The factory must use an impact screw stick to put those things in there. Ignition pliers work well, or small vise grips
Be careful, a hammer was never made for use with a carb.... :applause:
With that in mind, I find using a No2 Philips bit (the hex drive bit type) and
a hammer works well, tap the bit into the screw, and then slip the driver in place and twist in the normal way.
Neil.
:thumbsup::ride::applause:
I'll be trying to do this tomoro!
another question,
the second screw seems to be really inaccessable! due to the frame getting in the way.
how can i move the move around to get to the o/s diaphram screw?
Cheers :ride::thumbsup:
