Best way to increase torq in CR125 ´04 ?
What is the single best mod to bring up the power on low RPM in a ´04 CR125 ?
port and polish, v-force 3 reeds, chang gearing
Thanks for the input guys.
I will start with gearing.
In what order would you recommend the other mods ?
What is the main gain with the V-Force ? (by experience please)
From my experiences, the V-Force will make the throttle response crisper and add some mid-range. Keep in mind when adding the v-force, you will probably have to mess with the jetting, but it will be worth it.
Personally, this is one of the first add-ons I get, the other is exhaust. After that suspension.
i dint rejet for my vforce and mine runs fine
Put a 53 tooth sprocket on it, or if u already have a 53 just go up a tooth or so it should have a 52 on it stock. I have a 2004 cr125 as well. So just go up a tooth or 2 on the back sprocket
what about the fmf gnarly pipe it says it makes a powerband like a thumper :thumbsup:
those dont fit on 125's
