Help with Top Triple clamp Measurements??
Anyone know what the the top triple clamp on a 05 RMZ450 measures from the center of one bolt to the other?
Rob,
I would be glad to help you but I am not sure that I understand your question. Sorry.
Pinch bolts, bar risers or do you mean the distance between the fork tubes?
KT
On the top bar mount I was just looking for the distance between the farthest two bolts that hold down the bars.
3.776" center to center. This is taken from a stock top bar clamp that I have here. The holes are machined for clearance on a 8mm bolt.
Good luck.
KT
