Drz problems
My drz has seemed to consumed enough oil to be on the end of the dipstick in 220 klicks. Could it be that I had layed it on its side and for oil the oil to by pass the rings. I had layed it over about 3 times. Also the bike has 1240 kms on it total.
Are you doing the correct "oil check procedure"?
3 minutes of running and then off for 3 minutes then check the oil level
Ohh maby most of the oil is in the trans because the bikes been sittin fer 2 days.
That would be it most likely - you'll find it slowly seaps back into the cases over time
Yep, my bike does the same: let it sit a few days and do the 3 minutes thing and the oil level will be at the bottom of the stick...
