New under bar damper mount
I finally got my Scotts damper set up on my Husky and it works awesome!The Pro Taper bars are a great addition too. :ride:
With the Windham bend this set up is 1'' taller than stock,so if you are a tall rider like myself (6'5") you will like the extra room!Here are some pics. :thumbsup:
05 TE 450
Leo Vince
http://i90.photobucket.com/albums/k272/husky666/barmounts002.jpg
http://i90.photobucket.com/albums/k272/husky666/barmounts004.jpg
http://i90.photobucket.com/albums/k272/husky666/barmounts011.jpg
http://i90.photobucket.com/albums/k272/husky666/barmounts023.jpg
http://i90.photobucket.com/albums/k272/husky666/barmounts024.jpg
I have the same set up but the Windham's felt TOO high. (I'm ONLY 6'3") I swapped out to a Suzuki/KTM low bar, less height and less sweep, it measures out almost the same as stock, now I just need to get used to the tight fit of the adjuster wheel (the larger style knobs almost touch the bar).
Mine's from BRP / UP-Tite.
The adjuster wheel is optional,you don't have to use it but you will need to change the set screw that holds it on.Mine came with it and I turned it down to make it fit.
05 TE 450
That's really nice, but your gas cap is not on straight!
Man does that make me nuts.
HuskyRips :thumbsup:
