Jetting Help... Burned?
I have done as much research I could using the search feature but I just want to make sure I understand what I should do. I need your help Burned, guys. Thanks!
I have a 06 DRZ400SM with
Full Yosh S/S RS3 without insert,
3x3 air box, stock air filter but going to switch to a K&N,
and I just got my Dynojet kit.
What Jet set up should I use at 100' above sea level?
Do I need to get a fuel screw or can I use the stock one?
Do I need a new pilot jet?
Thanks again! :thumbsup:
Thanks Burned! Ill keep you guys posted.
What type of head does the stock fuel screw have? Is the extended fuel screw just easier to tune?
