Ufo help
Ok so I got my uf o rear light todat and i have started installing it but i need some help. I have already searched all of over the site and found nothing. I need to know what to cut and what to drill and where to put wires. Well if anyone could help it would be greatly apreciated.
Donut_01
Which DRZ are you trying to put the UFO light on?
Al E
Here's how I did mine:
Cut the tabs off the stock rear fender.
Drilled two holes in the UFO and used the stock mounting screws through the top:
Drilled 2 small holes in the tail light assembly for 2 tie straps:
Probably not the cleanest or best, but it is very stable. Didn't trim anything other than the stock fender's tabs. Doing it this way, you don't have to have bolts exposed on top of your fender.
WGW
