02' ttr-125 clutch push lever removal???
On a 2002 ttr-125 is there a trick to removing the cable push lever after the circlip has been removed?
Looking at the owner's manual it appears the push lever should simply lift out of the crankcase. In my case it does not lift out and feels like it is still being held by something that the manual doesn't cover. :thumbsup:
did you take the bolt off the engine. if you take the off and push back on the hook thing on the case it should come right out
Where is the bolt? Can it be seen on the side of the engine or do you have to take a crankcase off or something ? :thumbsup:
CopyofDSC00284.jpg you cant see it very well but it is visable enough to get the general area
same thing with kx 65
take the engine cover off and walla
its comes out its held down by a rod and a bearing to engage the clutch so once u pull it away it comes out can pull up
Is that the one that holds the bracket for the clutch cable?
Well now i don't know what to do because we already tried that. :thumbsup:
It turns out there is a bar that connects to the lever that holds in.
take a pic and upload it..im not getin what your sayin :thumbsup:
