picking up my first four stroke tomarrow need help
im picking up a new yzf 250 tomorrow, how do you break them in, and any think else you think i should know
the owners manual should come with the bike. it will have the break in procedure for your bike. just in case here you go:
warm up engine, operate in lower gears at moderate throttle openings for 5-10 minutes.
check how the engine runs at 1/4 - 1/2 throttle (low to medium speed) for about one hour. turn off bike, let cool down. restart engine and check operation through the entire operating range. if everything seems to be ok, then run for another 15 minutes.
after break-in check all torque points, and you may want to change the oil. when you do check the screen in the frame, clean if needed.
