a few clutch questions?
When installing steels I read that the rough egde should be oriented in a certain direction. Is this true and if so which way?
Would anyone reccomend new stiffer springs with a high comp, cams, fcr39, full yosh and open box?
My clutch is slipping a bit and im not certain why. Maybe I didn't soak the plates in oil for long enough (1/2 hour) or maybe the springs. Im pretty certain that the different diameter plate went in first but I will recheck today. And the lever freeplay seems good.
When I did my clutch I replaced the driven plates, friction plates, springs and basket. I went with moose racing stuff on the recommendation of burned.
Not sure if the springs are stiffer than stock or not though.
