xr70 acceleration gain?
What is the cheapest way to get a xr70 to have fast acceleration? I dont have a lot of money so the cheapest ways possible. once i get my job in oct then i will spend a ton!
Yeah, 13 tooth front sprocket, pod filter, trim the spark arrester if you only ride at closed tracks, and rejet and the bike should go from 3.6 to 4.2hp, and pull MUCH better.
i went with the 14 and did the exhaust mod and dropped the clip on the needle one and it helped a whole lot... my dealer got the wrong pod filter, they got the one that fit the 50 carb so when i get that on there i will probably drop the needle to the bottom clip and should be good.
