Best oil for High Altitude
i have a 97 xr4 and have been running the Honda High Performance 4-stroke oil, i seem to burn a lot of oil but my bike does not smoke at all. any recomendations on a oil that will is better at high alt? (9000ft+)
Ya know, I've never seen any discussion on oil viscosity/type or what-have-you versus elevation.
Are you sure you're checking the oil level correctly, as it's done a specific way to get a correct reading. Do a search here.
I've run the Honda HP. It's a good oil IMO. What viscosity are you running?
I second Trailryder on this one...make sure you are checking the oil level properly. I agree that HP4 is good oil also - should be fine.
alright, i did a search a found a thread about the correct way to check oil level, thanks!
