kitaco inner rotor kit
Tools You will need:
14mm socket if its a honda based motor or 15mm if its GPX motor
17mm Socket for flywheel puller
Flywheel Puller
Thick Phillips bit for Impact driver
Impact driver
Remove:
Flywheel nut
Flywheel
(2) Phillips head screws on stator plate
Remove stator carefully
Inner rotor directions are in Japaneese so if you need help wireing it let me know. and I will help you set the pick-up also.
