front fork seal
I had a look at the TT store but i couldnt fine one, does anyone know where to get on for my 2001 e?
or even better any UK riders know a good place to order from? I dont have a local shop where I am at the moment.
Thanks
If your seals are leaking, I've got something for you to try first. There's a product out that's simply this plastic film shaped like a fat hook. Slide it under the seal and use a scooping out motion to dislodge any grip that's under the seal. Keep scooping and wiping and withing a short time there won't be any debris under there and the seal will "seal" again. I've done this to 2 bikes and the seals are like new again and have not started leaking again even after many tough rides.
The thickness of the plastic is that of x-ray film. See your local x-ray lab or chiropractor's office for used film. One sheet can make dozens of these things.
I do take the forks off the bike to get better access but you can try it with the forks in place if you want.
Good luck. :thumbsup:
