Is this an "E" exhaust?
It doesn't have the little guard on the can like my SM does. The seller said it is from a KLX400, but didn't know if it was from the dirt only model.
If it is an "E" exhaust, can I use the entire system and keep my rear pegs? Or would I have to use the SM can?
I think its only the E that has that welded mounting plate on the silencer and the E shouldn't have a baffle in it either.
colhog,
I think I read somewhere that the UK E exhausts are considerably different than those on this side of the pond.
I haven't received the exhaust yet. if Steve is right, and it is an E model, then the headpipe should be larger. My SM is getting little "used" upgrades :-)
I've got used "E" cams, a used billet exhaust tip, a used KLR650 CVK40 carb (which made a huge difference), and I'm hoping the larger headpipe will give me just a little more.
Don't know the significance but I picked up a used Scorpion exhaust from a SM and it looks like the header pipe must be shorter, as the link pipe for the Scorpion is too long to fit the E header???
