is this spark plug burning ok?
i couldnt wait any longer for those giant pics to down load.
spark plug color really doesnt mean much.
how does the bike run.
if oyu down size the pics i will look at them.
From what I can see, it looks pretty good to me.
Thanks thumperwrestler just got back and you already had the job done. Eddie cable is really cheap these days :thumbsup: naw I know its my ISP's (employer) crappy transfer rates, in network it is fast though. Sorry
Bike runs ok. Just a small small off idle bog. for example I cant "snap" the front off the ground in first. I have to go a little then pin it to bring it up.
All you can say from that view of the plug is that the heat range is about right, and the spark advance is close. You can't tell much else about jetting by looking at the tip of the insulator or the electrode.
Plug color is only useful for checking the main jet, and only at the base of the insulator. If you want to check your main jet, install a fresh plug, do a wide-open run through the gears, kill the engine and coast to a stop. Remove the plug, and remove the threads. The mixture ring at the base of the insulator should be a medium tan, and about 1mm thick.
These will help you to read plugs correctly:
http://www.tsrsoftware.com/images/sparkplug.gif
http://www.tsrsoftware.com/read-plugs_files/sparkplug b-w .gif
looks rich to me.
but could be any of the circuits.
a plug from a properly jetted set up will look almost new out of the box.
reading the carbon ring on insulator doesnt work either.its not a 2 stroke.
btw,im on a T1 line and those pic were taking forever to load.they were huge.
I true T1 is 1.544Mbps... should have taken about 12 seconds.
With all the jetting quetions around here I doubt if Burned has 12 seconds to spare. crazy.gif:thumbsup::ride:
