BBR SP5 disc brakes
I've got the BBR SP-5 forks on my CRF, has anyone put hydraulic disc brakes on them? Looking for different options to try, goint to switch to 12" wheels anyways, thought it would be a good time to upgrade the brakes too.
Kinda way to expensive.
Get the Storm setup, works incredible for a mechanical cable setup, I run it and cant believe how strong it is. And later if you want to convert it to hydraulic, it can easily be done.
Check it out, heres a site that has all the parts you would need to convert to hydraulic, http://www.universalcycles.com/company.php?Company=Hayes.
Its all Hayes disc brakes which is what Storm uses, so anything is bolt on to the adapter Storm sells.
Thanks for the heads up on the storm system, looks like it may do the job, not into any hardcore stuff with the 50 yet.
