front wheel spacer
Anyone know? Is the front wheel spacer (brake side 06) the same on both ends? Meaning is there a right or left/inside-outside. It looks identical to me and I don't have the proper measuring tools available so I'm eyeballing it. Both ends seem to fit in the seal snug and again look the same. I just don't want to make an idiot mistake.
it should have a small ring machined in it where it goes into the seal !
I could see a small ring. I put that end in the wheel but the ring does not go all the way around the spacer and almost looked like more of a rub mark. I thought it may be some wear mark from riding in the wheel. Wonder what that is all about- spacer made friday at 5:00? thanks for the feed back. I plan on getting some aftermarket spacers that will hopefully seal a little better.
