Replacing only intake valves?
My intake valves are out of spec but my exhaust ones are still well in spec. Could i only replace the intake valves and not the exhaust? Would i have to use the genuine Honda valves to match the exhaust or could i use ss valves?
yes,that is what i did on my 450,just make sure to have the seats cut and install new springs as well.try the tt oem store for parts or check crotchrocket.com.i would go with the stock parts.if your going with ss i would replace all four because you will need stronger springs.
I agree. If you have >50 hours on the machine, I would cut the valve seats, new springs and SS valves for the intakes.
