dash computer question!
does anyone know how to reset the computer on an SM610 to get rid of the flashing oil can thing?
This was posted a while back by Xfool:
http://www.thumpertalk.com/forum/showthread.php?t=330436
2nd to last paragraph:
"OIL WARNING LIGHT: I've seen a number of posts where people thought this was a low oil pressure warning light. It is not, it is an oil change light. Whenever the maintenance interval set in step 8 is exceeded the oilcan symbol will show up on the screen. To reset the speedo hold the MODE button down, turn on the ignition on and continue to hold the MODE button until WS appears in the lower right of the display. Release the MODE button and cycle through the setup screens to the oilcan. Press and hold the MODE button until "----" appears. Release the MODE button and you will get a screen with "NO, clear?". Hit the MODE button and you will get "YES, clear?". Press and hold the button until the screen blanks and the interval will be reset. Turn the ignition off or cycle through the screens to the END screen and press and hold the MODE button to exit setup."
Good luck!
