Ohlins shims cross refrence chart??
I'm trying to revalve an ohlins shock using shim specs directly from Ohlins. I have their part numbers for shims, but would like to pick up the few I need at a local suspension shop. Shims are pretty universal but no one seems to know what the Ohlins part numbers mean as far as real dimensions.
Does someone have a chart cross refrencing Ohlins numbers to actual dimensions? They look something like this 525-38 which seems to measure out to .25mm (.010) thick by 38mm od. I don't know what the "5 could mean? then I come across a 610-36 or a 1115-34??
Ohlins is hard to get help from becuase they don't want you working on your own stuff. Its also Saturday so I can't try calling them again, just hoped someone would know the secret code or have a chart online somewhere?
