2006 yz250f oil question
I have a minute question about the oil measurements for the yz250f '06. There are three measurements, but the should be only two. Can someone tell me what measurements are for which?
-thanks
One is for the total oil amount that the engine can hold - which you don't use.
One is for changing the oil without changing the filter - which you do use.
One is for changing the oil and the oil filter - which you do use. This is the one that you should use, i.e. change both oil & filter:
http://av-motorcycles.gotdns.com:9296/06YZ250F/changing_oil/index.html
