Throttle flat spot
Hi Guy's,
I seem to have a flat spot when I just open the throttle slightly (About an 1/8 of a turn past idle). Because it's a new bike (only 200 Km) and I'm still running it in I've only been cracking the throttle lightly during riding.
Does anybody else have the same problem?
tjdrz400e
Take the snorkel out of your airbox. To do that take your seat off then take the snorkel out.
Hi Guy's,
tjdrz400e
It may not have been set up properly at the dealer.
Could just be a simple carb adjustment. Bring it back and have them take a look. I think i would wait a bit and get a few miles on it before doing any mods. :thumbsup::ride:
I have taken the seat off and can see some sealing compound at the top of the air box opening indicating that there was some kind of fitting there which may have been a snorkel, but I suspect that the snorkel may have already been removed on the Australian models.
What are your thoughts on removing the one way water valve at the bottom of the air box as well?
No, I wouldn''t remove the one way valve!!@! Just do the 3X3 mod by openening the air box more. Alot of mud, dirt, rocks and Water might get in if that valve is removed since it is at the Bottom of the air box. Not to mention the ocasional deep water crossings I come across, water would have gone into the air box!
G'day tj,
Yes I have the same problem. It usually happens when I'm on and off the throttle in second gear, right at the moment when you want to lift the front wheel over something. :thumbsup: From new my dealer removed the rubber snorkel from the top of the airbox and the baffles out of the muffler. Have a look at the three bolts on the end cap of the exhaust, if one has a tack weld on it then the dealer hasnt done the exhaust. I have read on this forum about a JD jetting kit which may fix this problem. I am just living with it until I decide on an aftermaket exhaust.
