Problems starting after rebuild?
ok so i just rebuilt my engine and it has about 2 hours run time on it and its broken in, and now to start it i have to pull it with my pickup and pop the clutch :ride: it is a 1994 cr125r :thumbsup: i put a new piston in it and v force reed valves when i rebuilt
im thiking its the carb but im not 2 sure im trying moving the needle clip up one 2day
What's your starting procedure? Are you giving it gas when it's cold? Is the choke on?
How's the bike run after you bump-start it? Is there excessive smoke?
And FYI, the needle will not effect how the bike start, the pilot jet and air screw will.
:thumbsup: Exactly!
Did you put a stock piston back in? Did you or someone measure the clearences of bore to piston, or ring gap?
Did you check compression? Retorque head bolts to factory specs? Is reed valve cage seated good and carb boot tight?
Check the basics before panic mode.
