ok put the DRC on Tonight?
Listen this maybe stupid, but I had to install the bracket below the sub from instead of the top of the sub frame as the directions say to do. When I did it way the directions said the stock turn signals would hit the rear fender and make them droop down. Doing it my way they don't hit anything, but there is a gap between the top of the tail light and the rear fender. Is this the right way with the stock turn signals, or is there something else I could have done to make it fit better. l any better ideas are appreciated, If anyone has any better ideas using the stock turn signals; I would like to read about them? Thanks. :thumbsup:
I cut the rubber on the stock signals so they would clear the fender. They aren't perfect, but they look OK. I mounted mine on the fender tabs with a clamp for extra support. Don't have any pictures.
