mod kill switch into a headlight switch?
Found nothing with a search :thumbsup: but it seems like I read about someone who changed there kill switch into a headlight on/off switch for off-roading. I would like to be able to turn the head and tail light off with that switch. Anyone tried it or know of a link? Thanks in advance.
I believe somebody tried this mod but found out the hard way that the bike still needs to send the volts somewhere and he burned up his regulator....i will try to find the post fore you.
And what would you do for a kill switch? :thumbsup:
I use the key switch to shut off the bike.
I meant in a panic situation. I hope most would agree , another type of switch setup would be better. If you ever have a throttle hang etc. you will not be able to leisurely take a hand off of the bars and turn the key off.
That is an excellent point! :thumbsup: I guess I should look for a nice waterproof switch. Thanks Motor-N
http://www.virtualinventories.com/vi2/images/products/main/Lockhart%20Phillips%20H-4%20Headlight%20Switches.gif
Lockhart Phillips H-4 Headlight Switches 2004
Today’s sportbike batteries are smaller and lighter than ever, and are easily drained during startup and slow city driving. LP USA’s on/off switches for motorcycles with H4 headlight bulbs cure this problem. Installation takes less than five minutes. Choose between handlebar mount or universal panel mount.
Man, the power of Burned. Within an hour of posting something, it's sold out!!!
Check your local laws,
I believe here in the Peoples Republic of Kalifornia it may be illegal to have a taillight blackout switch.
Something to due with evading law enforcement officers easier at night.
I may be mistaken though.
I removed the headlight from my E model. Do I need to be concerned about this?
INTERESTING, how do you wire this to cut out the brakelight/tail light?
I would like to do this too! I have a wiring diagram and will be figuring it all out soon. But extra input is always welcome. :thumbsup:
Taking away the grounds to the lights is one way. The OEM UK light switch is on my wish list, so I will be following this thread closely for ideas/instructions :lame:
If you look at the difference between the UK style RH control diagram and the USA model you can see the 2 wires you need to switch on and off with a DPDT switch from radio shack or where ever. One of them is gray...damned if I remember the other. If you get stumped yell maybe I can help more :thumbsup:
has anyone got a scanned copy of the wiring diagram so as i know where to cut into the loom to perform surgery ?
Cheers Graeme.
it very easy to stall a bike. just grab brakes and let clutch out. viola, your bike is off! no switches, no keys, just a lil slip o' the finger and you're there.
--keith
Yep! And the odds are you didn't use up that last 3' between you and the 25' drop off the trail, or that speeding SUV bumper. You always ride with your brakes and clutch covered, in gear and with good traction, don't you?:mad:
stalling is free, easy, and everyone has done it! so they can never say they don't know how!
and you SHOULD ride covering brakes clutch and be ready to react for everything on road or off. if you don't, you're a hazard to everyone around you!
and you don't need traction to stall your bike. i know you've done it in the mud too!
eddie- can you shut the head and tail light off with a switch like this, or just the head? just wondering, thanks!
--keith
