DRZ400S Jetting
This is probably posted elsewhere but I could not find it.
2005 DRZ400S
All stock, no mods except tires.
Engine will only run when throttle mid-range to full open. Have not touched anything since last ride and it ran fine then. Vacuum lines hooked up - no air leaks. Suspect pilot system clogged.
Since I'm taking carb off, I figure I'll pop a Dyno Stage 1 in there WITHOUT the 3x3 mod. Question: What settings should I use? Dyno recommends:
Groove #4
130 main
3.5 turns on mixture
no info for pilot.
Thanks! :thumbsup:
Thanks Burned! 25 pilot jet is the stock jet (I assume?). I did see your posting on confirming the pilot circuit settings.
Thanks for the timely response! If it would benefit the forum, I'll post the results when the job is complete.
