DRZ jetting
Just lookin for some quick #'s :thumbsup:
I ride from 1500 feet in town..and then offroad from 1500-5500 feet.
Stock pipe, 3x3 hole, DJ needle/spring.
Hey eddie what is the signifigance of the clip? its on 4th clip now...has a 134 main in it i need to go higher..course at 1500 feet its hesitating pretty good, just too lean, but yeah..
basically just curious about the clip..does it affect the main circuit? pilot?
Basically what ive got now is:
134 main, 25 pilot..4th clip.. So will order the 136 main (if i rarely get to 6000 feet, usually more 4000ish would a 138 main be better?)
Thanks again burned! Sorry im kind of all over the map :thumbsup:
The clip raises the needle out of the way of the gas coming up from the main jet. Count clip/rings from top. The lower you go the richer it gets.
Eddie is MUCH more knowledgeable than me on this and I am sure he will clarify byt it richens the midrange circuit of the carb from 1/4 to 3/4 throttle.
