xt225
my 05 xt225 was running perfectly fine then i went over a very little bump and it stalled and it wont start up again without the choke on even if it is warmed up when you put the choke in it will die. this happened before right after doing the same thing and i just messed with the idle screw and it worked again but now after messing with the idle screw it still wont start unless the choke is on. anyone know what the problem is
check your carb boot. the clamp might be loose or the boot is torn/leaking leaning the bike out.
