rear sprocket search
Need to find a 40 to 42 tooth rear sprocket for a SSR125E. I read in the search a 2005 RCM might work, anyone have a clue, and if it does where de hey do you buy RCM parts?? Outlaw, any help would be great!
I have two black steel 41 tooth sprockets that should fit if you are interested. I also have an aluminum 35 tooth. These sprockets fit sdg, rcm, and bxm so it will probably fit your SSR.
I sent one of these sprockets to sprocket specialists a while back and had a few made up. They now sell them. You can call and ask for Jonna. Just tell her you need a sprocket for a SDG. The part # is 4291-??(just put what size you want where the ?? is). They sell them for $47.99 + shipping. I will sell you one for $35 shipped.
I used the 37 for myself and sold the 32 already. Have 2 of the black ones(41). The second one is the 35.
mello sent me the measurements for the SDG- hole center 75mm, center to center of bolt holes 65mm, distance of bolt holes across center 92mm.
SSR- hole center 55mm, center to center bolt holes 50mm, distance of bolt holes across center 70mm.
Found out the SDG sprocket will fit the Rocketa 125 though..
