raspy sounding exhaust above 1/2 throttle
I have an 06 XC450. I was on a 100 mile trail ride yesterday and around 70 miles the exhaust tone changed (it got louder and raspy sounding) above 1/2 throttle. It seems a litttle down on power above 1/2 as well. It runs fine below 1/2 throttle. I suspect the TPS is bad, not advancing the spark as it should for higher revs. I asume that the retarded spark timing at high rpm is leaving incomplete combustion causing after-burn during exhaust stroke and that is what I am hearing. Has anybody experianced this problem? What are the correct resistances when measuring the TPS output leads at closed and full positions?
Happy Trails,
Jeff
My xc did the same thing when my PMB endcap S/A got loose. Silicone sealer at the joint from the core to the S/A, and new packing fixed it.
I found and fixed the problem, The intake valve clerance got tight. I adjusted them and now my 450 runs like new again. BTW,the TPS tested ok on the bench and was not the problem.
