SM AFRs?? (eddie)
I almost finished getting my wideband setup done for my SM. Still need to make up a rpm filtering circuit as my controller doesn't have an rpm input. The software has been done for ages... just need to make up the converter.
LSU in the pipe...
http://www.fetzervalve.com/LSU_DRZ.jpg
Display on mirror...
http://www.fetzervalve.com/PALM_DRZ.jpg
Wide band in man purse...
http://www.fetzervalve.com/WBC_DRZ.jpg
Does anyone have a list of target AFRs that work for the SM? I haven't messed with it much yet because I don't have my rpm input done but I did take it for a spin...
idle 11.5-12.0
1/2 throttle midrange ~14-15
1/2 throttle near redline ~15-16
WOT midrange ~12.5
I sware the bike ran better last week after I moved the needle to the 3rd clip. It now seems like something is plugged. Anyway, here are my settings...
- 3"x4"
- 150 main jet
- 25 pilot jet
- 3rd clip on needle from top
- 2.5 turns out on fuel screw
I have a KTM950 and have been in contact with a guy in Australia that has a wide band hooked up.
The ratios have been around 13.8-14.2 at idle
13.5 at mid-cruise
13.8 at high cruise
12.2 at WOT
Thanks guys.
Eddie, are my results surprising or is this just part of cutting the hole too big?
Is that some kind of Dyno? Please explain F4ight.
Does that wideband have the heating element built into it? Also what kind of output does it have. I have been looking for a good wideband so I can interface it into my data acquisition I have on the Dyno I am building. I need a simple 0-10 analog signal. Any help would be greatly appreciated. Cheers
Yes it has a heater built in. All current pump wideband sensors (NTK, Delphi, or Bosch) need to have tight heater control to maintain accuracy. The setup I have is almost one of a kind... I designed it for the company I used to work for shortly before I left but not too long before the CEO drove the company into the ground. All I took with me were a few pre production prototypes. It has serial as well as 0-5V analog outputs.
There are a bunch of companies making widebands nowadays but you can't go wrong with an Innovate LM-1 or LC-1 for best bang for the buck. I haven't heard of a company having a 0-10V analog output but 0-5V works just fine.
all the widebands i know of use 0-5volts.
results arent suprising really.
you did reuse all of the spacers on the needle correct?its a SM kit for sure correct?
Ah yes. I don't know why I am thinking 0-10. It is indeed 0-5. F4ight, where is a good place to purchase one of these. Im a college student on a budget and the loan I took out to build this dyno is already gone. I don't need one but I just really don't see the point in having a dyno if you can't see how the bike is running.
yes,mostly becuase of the gauge.i leave one of the ones i have permanently mounted in my lightning.
the software is much nicer on the commander as well.
you can realt time data log via lapt top etc.
Correct spacers... DJ kit# MQ3110.001. I am going to try duct tapping the air box closed to 3"x3" and put the clip back on 2nd position down.
