Argh!! Tips on removing bolts
Anyone have any tips on the easiest way of removing bolts "sans la tête" ?
To be specific, I was tightening the bolt in the oil pressure check hole on my
'06 YZ250F ( yes I was using a torque wrench) when :thumbsup: the head sheered
off. Is drilling and tapping the ONLY way ?
Thanks
get some of those nifty craftsman thangs that help take bolts out like urs
i dont no the name or a link but search for craftsman tools i rekon
If the shank of the bolt is sticking up a bit, you can possibly use vise grips to pull it out, but if it's sheared off even with the case, you will have to drill. One option is to buy drills that actually drill counter clockwise so when you drill the bolt, it could loosen up and back out the bolt. I've had great luck with that style of drill bit. You have to have a reversible drill to make those drill bits work. Or do it the conventional way....drill with a conventional bit, tap, and install a heli-coil or time sert.
If those techniques don't work, then first be sure the broken piece is flat, if not file it flat, or use a die grinder and make it flat. Take a center punch and center punch it in center of bolt. Buy a cobalt drill bit (hardened to drill into bolts) the size you need. Drill hole in bolt. Buy a good quality easy out and extract your bolt. Don't break the easy out !!! or your SOL.
Good Luck! :thumbsup:
i actually broke the tip off of my EZ out once and it worked better haha but was your torque wrench a ft/lb or inch? i know my ft/lb one isnt sensitive enough for the little stuff and its supposed to be a good one. i use the feel method and i never get leaks or loose bolts ever. luck maybe? or talent lol
This technique has worked for me lots of times.
Get a sharp center punch or a chisel with a sharp corner. Place this sharp edge about 3/4 from the center of the bolt. Tap it with a hammer so you cause a slight divot in the bolt to get some purchase. Tilt the punch to about a 45 degree angle and tap it counterclockwise. Very rarely does this not work if the bolt is not rusted in.
You should not have to re-tap the hole. The techniques mentioned above should work. The bolt should come out easily, it is a different story if you snap the head trying to REMOVE a stuck/rusted bolt.
if u have a dremel or other rotary grinder, u can try grinding a straight slot in the top of the bolt and use a flathead screwdriver to get it out. i've done that several times and it's worked for me.
I use a left twist drill bit on things like is. There is no load on the threads (The bolt head is where the thing seals) so that thing should just spin out!
